LR4 air shock replacements..
Old Dec 22, 2021 | 10:30 AM
ugmw177's Avatar
Default LR4 air shock replacements..
Hello
What is everyone using for the LR4 front strut assemblies? Oem? Is there a good lower cost alternative? I have a 2011 and it seems as though the front is starting to sag on both sides.
Old Dec 22, 2021 | 11:59 AM
ljdiscovery's Avatar
It may not be your strut assemblies. It could be the hoses, connections or the manifold. Try the soapy-water test to determine the cause of the drop. Raise the suspension to off-road level and spray the strut boots, the hoses and the manifold. If you do need to replace the struts, we used Arnott on our LR3 when the struts had boot leaks. We saved a couple hundred dollars a corner. We were very happy with the results. Good luck. Phil
Old Dec 22, 2021 | 12:28 PM
ugmw177's Avatar
Thanks, Phil
Giverny03
LR4
43
Aug 27, 2025 01:00 AM
jpderouin
LR4
Apr 30, 2021 03:57 PM
dlonesty
LR4
Mar 31, 2021 10:33 AM
Collin Wickes
Apr 7, 2019 08:13 PM
iconoclast
LR4
Nov 16, 2017 07:20 AM
