lr4 air suspension issue
Old Mar 9, 2022 | 02:55 PM
ugmw177's Avatar
Default lr4 air suspension issue
ok, 2011 LR4 front air suspension was lowering overnight. I pulled the fuse and both front sides still dropping overnight. I replaced the front block and it was much better but still lowering a bit and worse on the left. I pulled the fuse again and let is sit overnight. only left side dropped. I figured it was a leaking bag as they appear to be the originals. I replaced the left bag. Car is still dropping an inch or so overnight on the left side. I have sprayed soapy water on the air line connections to the block and the strut with no bubbles. it is driving me nuts and i dont want to finish off my compressor which is already getting a bit noisy. Anyhow, has anyone introduced UV dye to the lines to look for leaks? I was thinking about disconnecting the line to the front block that goes to the lef front bag and putting in a small amount of UV due then reconnecting and running it for a few days and using a UV light to look for leaking dye. Only concern is introducing a substance into the system that is not dry.
Thoughts?
Old Mar 10, 2022 | 12:57 PM
ugmw177's Avatar
ok, update. Found the issue. Someone has previously spliced the line from the mid block to the front block in a place where i could not see it. Fairy soap happened to run down the line from my spraying it on the front block voss connectors and i by chance saw some bubbles forming about 2 feet down that line behind the front bumper cover. It appears to have been spliced with a brass double nut compression type thing. I have orderd a proper splice and some new tubing to correct.
The-J-Man
Jan 18, 2025 06:43 PM
Rustic
Jun 19, 2020 07:15 AM
HurricaneK
Jan 14, 2020 08:44 PM
Enlund27
Feb 21, 2018 11:05 PM
cajun81
Dec 30, 2013 10:57 PM
