LR4 interior lighting
Old Aug 1, 2013 | 10:12 AM
brandino's Avatar
Exclamation LR4 interior lighting
my interior led lighting in the door handles and around the gear shifter have all just gone out at once...i have tried fuse 57 and 21 and they are ok..any help would be great !!!! thanks
Old Aug 1, 2013 | 10:57 AM
warranty?
Old Aug 1, 2013 | 11:05 AM
roverguy7's Avatar
What year?
By the lighting around the gear shifter, do you mean the illumination from it, or the light that shine down from above on that area?
Does the analog clock illuminate?
Old Aug 1, 2013 | 11:48 AM
brandino's Avatar
its a 2010 and yes all the lights from it and the light that shines down on it..and the lights behind the interior door handles and map pockets
Old Aug 1, 2013 | 11:50 AM
brandino's Avatar
its a 2010 and no warranty...yes its the lights from the inside the shifter column area and the lights that shine down on it ..and the lights in the door handles and map pockets
Old Aug 1, 2013 | 12:09 PM
brandino's Avatar
and clock does not illuminate either
Old Aug 1, 2013 | 12:14 PM
roverguy7's Avatar
Back lighting of the shifter surround is on a completely different circuit then the ambient lighting in the doors, clock, and waterfall lighting from above.
What about the rest of the interior illumination, all the switches and such?
Make sure the dimmer dial by the light switch isn't turned all the way down.
Old Aug 1, 2013 | 12:25 PM
brandino's Avatar
anything that dims is out..i just checked...is there a dimmer switch fuse??? spedo lights...touchscreen and a few buttons will lite up...
Old Aug 1, 2013 | 12:34 PM
roverguy7's Avatar
Do the high beams, and turn signals work?
If so, you're looking at either the lighting switch itself, the CJB, or the wiring in between.
No fuse for the dimmer.
Old Aug 1, 2013 | 12:51 PM
brandino's Avatar
oh boy..the cjb does not sound like its alot of fun $$$$
