LR4 Low Beam Lights Will Not Come On
Hey All,
I have had my 2012 LR4 for a month now with no issues. Sunday evening when it got dark, I realized the automatic lights were working on the interior but had no low beam lights. I turned the light button to the "On" position and had no luck with my low beam lights either. I tried restarting the car with no luck and have checked the fuses associated with the external lights and all of the fuses are good. The interior, blinker, running, fog, and high beam lights are working. Does anyone have any suggestions on what other components I need to look at to solve this issue?
I would test the bulbs before you go any further. They are inexpensive. I found that some of the 'higher performance' brighter bulbs would burn out in an incredibly short period (like 3 months of normal use). So I went back to the standard ones which lasted for years. So actually quite possible that both just failed at a similar time
Eg I used the "Philips H11 Vision Upgrade Headlight Bulb with up to 30% More Vision". Loved the light quality and brightness. But the first pair did 3 months and the next 5 months...
mmbirtcher (04-24-2022)
