lr4 not starting after coolant crossover pipe replacement
Old Mar 16, 2021 | 06:57 AM
Daytonars7's Avatar
^that is correct.
the diverter plug is on the rear lower passenger side of the intake manifold.
the other plugs is as described above.
there are only 2 plugs in the area, and i think 3 plugs total to do the entire job. the third one being the throttle body harness.
Assuming you did the work for the crossover pipes, this shouldn't be hard to fix. it does require removal of the intake manifold though. You can barely reach the coolant temp sensor, but there is no way to reach the diverter valve plug with the manifold in place.
Zazie2020
LR4
Apr 9, 2020 12:26 PM
elboy0712
LR4
Oct 15, 2019 05:50 PM
MATT04
Sep 15, 2018 01:07 PM
chubbs878
Dec 24, 2015 08:44 AM
aftermath431
Jan 23, 2014 10:06 PM
