Lr4 overheating
Old Jul 1, 2024 | 06:51 AM
Luzbelchilango's Avatar
Default Lr4 overheating
My 2016 land rover lr4 when it is parked the temperature is normal but when I run it the temperature rises a lot and the check engine doesn't turn on...what could it be? Has it happened to anyone? I really need your help
Old Jul 1, 2024 | 07:35 AM
Rustybolts57's Avatar
Thermostat not opening could cause that, or maybe air in the system.
I am assuming that you have checked the coolant level.
Old Jul 2, 2024 | 08:08 PM
jahummer's Avatar
There's ECT A and ECT B. A can range anywhere from 190-230s F whilst B anywhere from 90-over 200F depending on whether you're driving or stationary. You won't get a warning until it gets to 250 F, danger zone's usually 270 or higher.
Old Nov 13, 2024 | 01:04 PM
Disco1toLR4's Avatar
Default 2015 LR4 V6 temp gauge
My 2015 LR4 V6 temp gauge goes from Normal to 3/4 to Hot and back in 2 steps about 1.5 minutes. Only does it once on a 10-12 mile run. Not losing coolant. Air lock? 89K miles and crossover pipes replaced and the water pump a year ago.
CKIST
LR4
May 28, 2026 01:07 PM
steevo67
LR4
May 10, 2024 10:21 AM
kst1980
LR4
Apr 28, 2023 08:53 PM
hawaiianbarbecue
LR4
Jan 8, 2023 04:09 AM
iconoclast
LR4
Nov 16, 2017 07:20 AM
