LR4 SCV6 multiple codes
Old Mar 26, 2024 | 03:09 PM
Raherrgott1's Avatar
Default LR4 SCV6 multiple codes
Dealing with several fault codes at once. Wondering if i did something when replacing plugs. The foam pads are difficult to fit. Took apart to see if i damaged wiring and cant find anything wrong. Codes are - P0458, P0691, P115F, P0598, P06db. Tried erasing all, but strangely the fan circuit does not erase and then others come back as well. Fan rund constantly and not sure if this is how it always has been. I replace PCV and purge control valve since should do anyway. Was thinking of replacing thermostat since this one has 60,000 miles on it. Battery reading 12.37 volts when sitting. Thinking ECU since cannot find any other issues and so many codes. Was hoping to find a lose wire or ground but cant. Any help is useful...
Old Jun 4, 2024 | 10:30 AM
Kaissias's Avatar
Bumping this post. I Have exactly the same codes on my car. Have you managed to resolve this issue?
Old Jun 4, 2024 | 11:10 AM
TheFixer's Avatar
Take apart all related connectors, clean with electrical contact spray. Before putting back together dab with dialectric grease.
Check for kinks and small breaks in wires.
Make sure battery is putting out required voltage under load.
Old Jun 4, 2024 | 02:17 PM
Check fuse 5 by battery. Mine was blown and still tracking to see why but i fixes the issue.
Old Jun 4, 2024 | 03:04 PM
guy's Avatar
guy
Emphasis on the battery! Bus communications failures can be broken harnesses but it is typically an inefficient battery.
It must read 12.6 v, resting for 6 hours, engine not running.
Also as our vehicles get older, emission errors seem to be more prevalent. Good call on replacing the PCV valve. MAF, O2 sensors, dirty filters, clogged cats are some of the culprits.
BNN_Rover
LR4
Jul 24, 2023 05:42 PM
SC Rover
LR4
Sep 14, 2022 10:30 AM
ScottPNW
LR4
Feb 18, 2019 08:28 PM
DiscoRover007
Nov 25, 2011 12:08 PM
bearcatfans
Oct 15, 2009 09:12 AM
