LR4 Speaker Grill Removal ??
Old Dec 27, 2024 | 01:14 PM
4th Rover's Avatar
6th Gear
Default LR4 Speaker Grill Removal ??
Looking to insight as-to how one removes my speaker grills (e.g. special means or without damaging)?
Appears the prior owner of my car messed around with the front in-door speakers, as there is something hanging from the top inside them that is visible. Also, the drivers-de tweeter isn't working and either needs wiring repair or replacement.
Old Dec 27, 2024 | 02:04 PM
CincyRovers's Avatar
You have to remove the door panel and remove them from the back. The grilles are crimped to the back side of the door panel, so you'll have to un-crimp them, and then they can be removed. They don't just pop off.
Old Dec 28, 2024 | 02:23 PM
4th Rover's Avatar
6th Gear
Thanks for the heads-up ... Of course some more brilliant British proprietary engineering to inconvenience owners versus something far easier, but likely the grand design to push us into giving up and conceding to the dealership to fix.
Old Dec 29, 2024 | 10:18 AM
guy's Avatar
guy
I’m afraid I can’t subscribe to the perspective. Do you really think the dealership wants the job of replacing speaker grills??
Anyhow, the other reason to remove the card is to clean the inside of the door and apply rust inhibitor while you’re at it.
Old Dec 30, 2024 | 10:27 AM
Well, most cars you have to remove the door panel to access the speakers. Not just a JLR thing. All you need is a trim removal tool and a screwdriver. It takes less than five minutes to remove the door card.
stephen.ertelt
LR4
Feb 3, 2023 03:04 PM
lrexplorer
LR4
Aug 12, 2022 04:43 PM
Landin
Mar 12, 2018 02:28 PM
jmillerau
Sep 2, 2011 07:56 AM
DeluxeRN
Jul 31, 2011 10:06 PM
