LR4 strange bell sound when wheel rotates right rear
Old May 1, 2024 | 04:17 AM
Jazzytris72's Avatar
4th Gear
Default LR4 strange tinny metal sound when wheel rotates right rear
Hi All,
Have a strange light metal type sound from right rear on each wheel rotation, in straight line.
Have attached a photo , but looked under and nothing obviously loose.
Cant upload the video to show sound, but its like a bell or thin metal type flicking sound each wheel rotation.
Appreciate if anyone has a clue as Im down in France this next 4-6 weeks...
The only thing I can think that triggered it was I went over a slightly high curb, but nothing that I would say would damage anything, but may have triggered a loose 'something'
Old May 1, 2024 | 09:13 AM
Hugh166's Avatar
I would take a look at the dust shield behind the rotor, maybe that got pushed in a little and is hitting. If you say it comes with each wheel rotation jack up it and rotate the wheel by hand to help locate it.
Old May 1, 2024 | 09:18 AM
4th Gear
thanks
could I access or see the dust cover without jacking up? Im a total layman and stuck here in France so hoping it’s something simple .
Old May 1, 2024 | 05:23 PM
Hugh166's Avatar
You can see part of it, just to the outside of the rotor. Take a long screw driver and just try pushing it in and see if the sound changes after
Old May 2, 2024 | 02:04 AM
4th Gear
thanks so much , sorry could you point out where and what the rotor looks like. I will be taking to a garage here hopefully today but curious
Old May 2, 2024 | 11:14 AM
Hugh166's Avatar
Look from the outside of the wheel into the slot in the wheel. The big round disk in there is the rotor. There is a dust shield behind that, you can see it at the outer edges of the rotor.
Old May 2, 2024 | 12:06 PM
4th Gear
update: took to a garage today for a quick visible check and they said oil fluid is leaking right on the gear box , he went under and wiggled the axle (or shaft perhaps), and it made the same metal sound.
perhaps it’s low on fluids? I can only assume it’s not good to drive any more until it gets to a garage? Would I have done any perm damage since yesterday , have driven about 5 miles with this noise
Mi2024
Sights N Sounds
Mar 3, 2024 05:41 PM
evan.byron@gmail.com
Aug 2, 2021 01:22 AM
Rover Chris
Jan 11, 2021 12:27 AM
csb
Jun 5, 2010 08:27 AM
Camdisco24
Mar 21, 2007 10:03 PM
