LR4 transmission fluid full volume exchange
Old Jul 22, 2024 | 09:33 AM
AGLR's Avatar
Short answer: I doubt it will change the outcome.
Long answer: That is how I would do it. Flush out what you can to get fresh fluid in there. Then drop the pan, do the valve body and solenoids and replace the filter. You will lose a couple L of fluid in the pan doing it this way though.
On the other hand, the direction of flow would be picking up fresh fluid directly through the filter after the pan drop, so even if you did the flush at the end, the filter and pump would really only see clean fluid anyway. This way would be more efficient in time and save some fluid.
Old Jul 22, 2024 | 10:29 AM
guy's Avatar
guy
From the horses' mouth.
File Type: pdf
yelxuhf
Jun 30, 2019 06:48 AM
Athana
Jun 8, 2019 10:23 AM
luckyd77
Jul 2, 2017 09:06 PM
QuakerJ
Apr 21, 2014 07:41 AM
Ewd777
May 7, 2012 04:15 PM
