Is Metal Transmission Pan Upgrade Necessary 6HP28
Old May 23, 2024 | 08:45 AM
500Benz's Avatar
Default Is Metal Transmission Pan Upgrade Necessary 6HP28
Hello everyone,
I just recently purchased a 2012 LR4 that seems to be on its original transmission fluid at 162,000. I am planning on taking this LR4 out west and on trails so I would like some fresh transmission fluid, diff fluid, TC etc. I am wondering if there are advantages to the metal pan upgrade beyond the better serviceability?
Does the pan significantly improve heat dissipation or durability? I would put the upgraded pan on a lower mileage unit but this may be the last or second to last change so I’m not sure if it’s worth the extra investment.
Thanks!
Old May 25, 2024 | 01:55 AM
guy's Avatar
guy
With millions of miles on these vehicles all over the world, and the skid plates under the vehicle, and with the coolant system connected to the transmission… there is no need to substitute the plastic pan with the metal one. Any “heat sink” property would be negligent due to the lack of cooling fins and air flow, anyways.
ZF has been using plastic pans for decades.
“Better” serviceability? Not sure about that either.
Old May 31, 2024 | 03:38 PM
keninnc's Avatar
Metal vs plastic is more about identifying if the transmission oil has been changed.
The aftermarket pan that is metal does not have the filter attached to the plastic plan as the original does.
This makes it a little easier to install but more importantly you can identify if your vehicle has had the transmission oil changed if it has a metal pan.
Jensen Vermont Stenberg
LR4
Jul 24, 2023 09:40 PM
M32H32IS
LR4
Apr 21, 2022 06:51 AM
Roverrrgirl
Dec 8, 2016 04:51 PM
djkronik57
Nov 9, 2016 11:26 AM
