MOST Bus Module Locations
Old Dec 17, 2019 | 09:14 AM
insite986's Avatar
Default MOST Bus Module Locations
Hi,
I've got a screen that's frozen on the Land Rover logo much of the time. Occasionally, everything works (radio, CD, NAV, etc), but most of the time it's locked up. I have the center console and mid-dash removed. I have a MOST jumper that allows me to unplug each module to see if the issue goes away.
There are five MOST components on my car:
Screen (located in dash & tests good)
Head Unit (Located in dash & tests good)
Amplifier (Located under passenger seat & tests good)
This leaves only the portable audio module & the HD tuner. In the tunnel under the center console, there is a MOST bus disconnect that loops through the amp, PAM and HD. When i jumper it, the system boots. I cannot for the life of me locate the PAM or the HD Tuner. The drawing in the shop manual is very vague; i thought the portable audio module was under the center console, however the only module under the console is for the airbags. As for the HD Tuner, maybe above the headliner? If anyone knows, it will help me a lot! thanks.
Kevin
Old Dec 20, 2019 | 06:45 PM
LR Techniker's Avatar
PAM is located under the driver's seat. HD Tuner should be behind the right rear quarter trim.
AnthonyC
Range Rover L322 (3rd Gen)
Nov 8, 2019 10:16 PM
ljdiscovery
LR4
Jul 21, 2019 02:29 AM
tedjan
Aug 1, 2014 12:04 PM
CSPM
Jan 29, 2010 06:27 PM
Cirrus
Jan 21, 2007 01:36 AM
