Replacing tailgate carpet with rubber/plastic
Old Apr 6, 2019 | 12:13 PM
johnnylib's Avatar
4wd High
Default Replacing tailgate carpet with rubber/plastic
This may be a dumb question, but it seems that the carpet on the rear tailgate is a collection area for dirt and grime. Is there anyone that has found perhaps a way/part to replace the carpet with rubber mat material? Maybe plastic? Anything better than carpet. Ideas? Thanks!
Old Apr 9, 2019 | 12:23 AM
DakotaTravler's Avatar
I bought a rear cargo area cover. It came in a couple parts, one being a small section for the rear deck. The cover sucked, a lot. But I did keep the deck cover installed. It attached via velcro and matches the dimensions. It perfect for my dog to jump onto and get some of that dirt off. You could probably get some rubber matting, cut it to fit and velcro it on or use button rivets.
Old Apr 9, 2019 | 12:19 PM
What brand cover did you have? I have been eyeballing one and if its the same brand I’ll skip it lol
Old Apr 9, 2019 | 12:24 PM
This cheap bastard:
https://www.ebay.com/itm/Land-Rover-...2/162112337283
The problem is the material is just too thin so it does not hang well or lay well. The fit was pretty good, its certainly not universal. One issue I had is that I lower the second row A LOT and the cover simply does not work for that at all. I may create one on my own and use button rivets snaps so I can remove it. I guess I was not expecting much for the price though.
Old Apr 9, 2019 | 03:20 PM
That of course is the one I have been eyeballing. Thanks for saving me the $70
Old Apr 10, 2019 | 08:22 AM
johnnylib's Avatar
4wd High
thanks!
Old Apr 10, 2019 | 08:23 AM
johnnylib's Avatar
4wd High
I recently contacted a seat cover company that may be able to make replacement coverings. Will update when I have info.
Old Apr 10, 2019 | 09:52 PM
Cool good luck
Old Dec 4, 2019 | 12:15 AM
HeadofthePac4's Avatar
Any luck?!
Old Dec 22, 2019 | 03:42 PM
johnnylib's Avatar
4wd High
not yet. kind of put it to the side for the moment. definitely needed.
SundayFunday
Jun 7, 2019 06:19 AM
Bhmdisco5
Jun 4, 2019 10:46 PM
drcoop
May 13, 2014 11:35 AM
LandRoverSE
Aug 1, 2007 12:15 AM
Sniper
Apr 7, 2007 12:28 AM
