Oil Change 2013 LR4
I am trying to get a definitive answer to the question of whether oil changes by a dealer are done through draining or by sucking the used oil up. Our local dealer charges about $240 for an oil change and "check" but if they don't drain it it's a useless task that I could do myself for about $50. I already have to air up the tires after the last service as they seem to want to have the vehicle ride "soft" by lowering the pressure about 5 lbs.
Thanks in advance.
Thanks in advance.
I still get underneath and remove skid plate a drain all the oil. I have a pump, but the PO did not do regular changes and I did a rapid succession of changes to maybe set it right. Oil for 8.5 qts.= $76 =+ 1 filter ( from Ebay ) $18, totals $94. A real savings with an hours time. Pump cost $99 from Amazon.
Land Rover suggests full synthetic. If dealer changing oil, will be synthetic.
QUOTE=Magnumforc;558496]Thanks for the answers. We only need one more change before the warranty is up so probably will go with full synthetic and extend the mileage between changes a bit. Very low mileage vehicle; this one is the wife's vehicle and has only seen less than 5K miles in three years.[/QUOTE]
collin Barrows
08-28-2011 07:13 AM
