Oil Level Check
Old Feb 26, 2025 | 05:22 AM
Conch's Avatar
Default Oil Level Check
2015 LR4 HSE. Found out how to check oil level but first time i had just run the engine for about two minutes and it stated NO INFORMATION on the dash, apparently because engine was warm. So, i waited until next morning before starting to check oil level and got an OVERFILLED indication. So is there any other way/process to do the check, or do I just need to drain some out? TIA
Old Feb 26, 2025 | 08:32 AM
CincyRovers's Avatar
To get a proper measurement you need to make sure that:
1. the engine is at operating temperature
2. the vehicle is on level ground
3. the engine must be off for at least 10 minutes, or you will not get an accurate reading.
Old Feb 26, 2025 | 09:44 AM
Conch's Avatar
Aye Cincy -
Was level (in garage), but had sat for several hours and was cold. Tried this morning and it stated it was OK at full mark. Will make next check after a run and letting it set for the 10 minutes.
Thanks for info.
ToiletDuck
Jul 19, 2023 10:02 AM
SeriousVicarious
Mar 2, 2023 04:59 PM
rogerh
LR4
Sep 10, 2022 08:56 AM
Jason Anzaldua
Jan 7, 2022 07:56 AM
osolupo
May 17, 2010 12:57 PM
