Rear air strut replacement question
Old Jan 18, 2025 | 08:56 AM
Nosralsk's Avatar
Default Rear air strut replacement question
Hey all,
I have a small leak in one of my rear air bags which causes the vehicle to lower to the bump stops every time the weather gets cold. I have ordered two new ones from Atlantic British and am planning to attempt to swap them out myself later next week. Just wondering if anyone has any tips/tricks to offer. From what I've found, it seems the steps should be:
Lift rear end up on jack stands and remove wheels
Unplug electrical
Remove 3 bolts and air connection from top of strut
remove lower bracket bolt (use bottle jack to support so it doesn't fall)
slightly tilt it at a forward and outward leaning angle and remove strut.
*i was also told to make sure i do not bump or disrupt the ride height sensors*
Is there anything I'm missing? Should i anticipate having anything to do with the control arms? Any tips, tricks, or things to be aware of?
Thanks in advance
Old Jan 18, 2025 | 02:54 PM
guy's Avatar
guy
Detailed instructions are described in the workshop manual.
Old Jan 18, 2025 | 10:01 PM
DakotaTravler's Avatar
Did you already service or replace the rear valve block? Rear strut leaks are not very common, less so than fronts. A leaking valve block is the number one cause of struts to dump air, so most tackle that first before doing the struts themselves.
Old Jan 18, 2025 | 11:17 PM
guy's Avatar
guy
Yes… Its best to perform the air leak test on the entire system to derive a diagnosis and repair.
Old Jan 18, 2025 | 11:18 PM
My comment was directed at Nosralsk.
Old Jan 18, 2025 | 11:22 PM
Nosralsk's Avatar
Yep, valve blocks are good to go. Truck still lowered to one rear corner over night with EAS fuse pulled.
As far as the workshop manual - is there a special one you are referring to, or is it simply in the owners manual? I looked it up and it seems there are several options out there for service manuals, would love to know which you recommend. Thanks!
Old Jan 19, 2025 | 06:42 AM
guy's Avatar
guy
No, changing up the air spring is not considered an owner’s maintainable service.
As @DakotaTravler has eluded, there is a specific procedure to follow before coming to any decision for corrective action.
Without experience or the workshop manual I suspect the pinpoint tests have not been followed and your diagnosis may be inaccurate.
Send me a pm and we’ll see if we can get you sorted.
Old Jan 25, 2025 | 09:01 PM
Lowrykun's Avatar
I'm curious if you were able to diagnose the issue. I replaced my front struts over the summer and replaced the front block and compressor while I was at it. Last week I had the rear-driver side lower unexpectedly, but hasn't happened since.
dnbrown9
May 4, 2022 12:32 AM
TOM R
Sep 26, 2019 05:02 PM
95_rover
Oct 24, 2012 04:23 PM
Infamous_Disco
Nov 20, 2009 06:09 PM
landRoverNewbie
Oct 13, 2009 11:39 AM
