Rear camber adjustment?
Old Sep 6, 2020 | 04:04 PM
Maxelam0822's Avatar
6th Gear
Default Rear camber adjustment?
Can you purchase an aftermarket camber bolt for the rear, mine is max out and need to adjust about 1/2 inch more? Thanks.
Old Sep 11, 2020 | 06:13 AM
Alphamale's Avatar
All the bolts for the rear suspension are readily available, you just need to know exactly which you need with the part Nº. If it's the one at the top of the rear knuckle then it's RYG000384 for the bolt, RYF000182 for the washer and RYH500191 for the nut.
username0010010
Range Rover L405 (Fourth Gen)
Jun 25, 2020 01:06 PM
honda50r
Jul 30, 2012 09:39 PM
drzjoint
Sep 6, 2008 09:39 PM
attabuoy
Jan 6, 2008 03:37 PM
05LandRover
Sights N Sounds
Mar 17, 2006 03:16 PM
