Rear Rotor EPB will not go on 2010 LR4 V8
Old Aug 4, 2020 | 10:13 AM
MkeRover's Avatar
Default Rear Rotor EPB will not go on 2010 LR4 V8
Hi Everyone,
I replaced my rear wheel bearing this weekend which lead me to replace the rear parking brake pads and hardware. In removing the right (passenger) side hub assembly I broke the cir-clip (HC-1 below) on the parking brake cable as it enters the back plate. This clip is under the plastic screw on cover / cap with a knurled OD and a hex. On the drivers side I realized I did not have to remove the clip to get the cable out of the backing plate, so I didn't break it. The problem came during reassembly.
The Drivers side rotor went back on just fine and adjusted great. However when I got to the passenger side with the broken cir-clip I could not get both pads to contact the lug that is opposite the star-wheel adjuster. The best way to describe it, is as if the spreader bar was too long. I tried loosening the spring loaded wedge on the back of the shoe (small M4 hex screw from front side)but it didn't seem to make a difference.
I bought the clip today from a local LR dealer so I'll be able to put the clip on tonight.
I guess I am preemptively trying to get some ideas in case the clip does not solve the issue. I find it hard to believe that the cable being into the backing plate a little further because the clip is not present would cause this kind of an issue.
Other factors:
I'm pretty confident I got the EPB in service mode before I started, however I did not get a notification that it actually went into that mode.
I was putting the old rotors back on just to get the truck on the ground - new rotors on there way, but that means they would be even harder to put on due to the bore being new and a smaller ID
I ground away (again temporary) the lip caused by wear in the brake bore to make sure it wasn't interfering.
Could I have bent the backing plate in some way while pressing the bearings out that is causing this? If so why didn't I see this same issue on the driver side, I used the same pressing techniques.
Thanks in advance for any thoughts you may have!
okdiscoguy
Jan 16, 2024 04:31 PM
JUKE179r
Build Threads
169
Dec 29, 2023 05:49 AM
Geo
Jul 6, 2019 09:24 PM
luxury1
Jan 17, 2009 07:59 PM
luxury1
Jan 29, 2008 10:14 PM
