Regarding the cross over pipes...
Old Nov 19, 2022 | 04:30 PM
tranmkp's Avatar
4th Gear
Default Regarding the cross over pipes...
This could be for the V8's and V6's
We can all rest a little better now that aluminum front cross over pipes are now available. Rear Crossovers are not (as of yet). However, are the rear crossover pipes required for the cooling circuit? Or are the rears more for the heating circuit? It would be so easy to just close off the rear head ports or use nipples with high temp silicon tubing and bypass the heater circuit if that is all it is.
thanks
Old Nov 19, 2022 | 04:55 PM
ugmw177's Avatar
where is an aluminum front crossover pipe available?
Old Nov 20, 2022 | 12:23 PM
jahummer's Avatar
Mostly from China, via eBay and others. Since JLR redesigned the front pipes as a one piece cast, I'd reckon there's no longer the failure prone to the previous 2-piece design...
Old Nov 29, 2022 | 06:45 PM
Androomantoo's Avatar
7th Gear
From what I can tell the aluminum crossover pipes only relate to the SUPERCHARGED 3.0 V6 and 5.0 V8, the NA V8 in the LR4 doesn’t have such an option yet.
Martinezma99
Feb 28, 2021 08:19 PM
jhill15
Jan 27, 2013 06:25 AM
MiamiC70
Jun 21, 2011 02:07 PM
jaydisco
Oct 14, 2010 11:18 PM
SpeedAgent
May 6, 2008 02:38 PM
