RH F&R carpet soaking edge wet when parked, not driving
Old Jun 17, 2024 | 07:43 PM
jahummer's Avatar
Default RH F&R carpet soaking edge wet when parked, not driving
Truck was parked and not driven. Heavy downpour. After the rain passed opened front a rear RH doors and found the carpet at the sill bottom edge completely sopping wet, including the carpet mats but the middle of the carpets dry and the front carpet dry on the 45 degree footwell slope. Door cards appeared dry as well so it appears water defied gravity and traveled up the sill and to the carpet.
Old Jun 17, 2024 | 09:01 PM
guy's Avatar
guy
Or
the sunroof leaks, or
the seal around the front windscreen, or
the seal around the moonroof...
Is the headliner wet anywhere? Any drips on the dash or seats?
Old Jun 17, 2024 | 10:12 PM
jahummer's Avatar
Originally Posted by guy
Or
Headliner dry, on windscreen #6, no leaks. Not the sunroof, had a 2009 Range Rover Autobiography years ago with the clogged drains AND leaking windscreen. Carpet ONLY soaked at the edge, on the RH side. It's done it before, driving through deep water and at that time assumed faulty door seals but this time the vehicle was parked when it happened. Heavy rain for an hour then sun came out and that's when I saw the water and I mean extremely soaked, pressing the carpet like squeezing a wet towel. I tried a pressure washer but could not duplicate the leak. Managed to get water to drain from the outside of the door windows and out the bottom of the doors. Going to keep trying, maybe a hose rather than high pressure.
Old Jun 18, 2024 | 12:19 PM
guy's Avatar
guy
Any signs the door was removed and reseated? Is the weather stripping misconfigured? out of shape? Overly compressed? If you put vaseline on the stripping and shut the door, does it leave a smear on the vehicle?
Old Jun 21, 2024 | 04:17 PM
nashvegas's Avatar
On an LR4, first bet on water ingress is leaking or detached, or clogged sunroof drain tubes.
Old Jun 21, 2024 | 04:28 PM
guy's Avatar
guy
I had the A-pillar exterior moldings off… on LR time there was some comment about sealing a hole on the pillar to stop leaks.
I have the hole, but no leak. There is a tsb but I don’t know what it is…
Old Jun 21, 2024 | 04:34 PM
kajtzu's Avatar
TSB = technical service bulletin
This one is for the D3, not sure if there is one for the D4 https://landroverforums.com/forum/at...water-leak.pdf
Old Jun 22, 2024 | 07:32 AM
guy's Avatar
guy
Thank you Mr Obvious, lol. I know what the acronym TSB means. What I don’t know is the particular number.
Thanks for the morning chuckle!
Cheers
Old Jun 22, 2024 | 09:44 AM
kajtzu's Avatar
well, I’m first to admit that English is not my first language but the way the sentence was constructed implied something else ….
kind regards,
Old Jun 23, 2024 | 03:10 PM
jahummer's Avatar
UPDATE:
Truck sat outside in a 15 minute downpour. The weather completely cleared immediately after and I went to check the floor, opened the door and water was pouring out. Used a shop vac and removed 2 gallons of water.
Here's a video
File Type: mov
