Stalling, shifting bad when cold... :(
Old Dec 17, 2017 | 12:16 PM
peterniez's Avatar
Default Stalling, shifting bad when cold... :(
Greetings All!
I have an issue with my 2012 v8 LR4 thats the dealer cant figure out.....
Car hesitates/rough shifting in lower gears when cold. When fully warmed up (30min drive) it behaves normally. Its gets worse the colder it is outside.
This was my original complaint at the dealer. They found nothing wrong, no codes. I quess because im almost at the end of my CPO.
Most recently I noticed RPM drop when stopping, (when temperatures got even lower) and now sometimes stalling when I come to a stop.
This happens only 2, 3 times then goes away. After it fully warms up all sypmtoms go away.
I tried cleaning the throttle and maf sensors, but that didnt help. I have made another appointment next week and I hope it happens to them...
Any insight would be great...
Thanks in advance
Old Dec 19, 2017 | 07:13 PM
Jhartz's Avatar
Check the temperature sensor . . . if it is not reading correctly, it senses the car does not need extra enrichment at cold startup. Not that big a deal in the Summer; a crisis in Winter.
Old Dec 20, 2017 | 08:01 AM
peterniez's Avatar
Thanks for the tip, will plug my scanner in the morning and check the temperature reading at cold startup. I assume (if its not working correctly) it should register a higher temperature than actual outdoor temp?
If I cant figure it out, I might just replace the sensor and cross my fingers.
Thanks again for the tip
Old Jan 4, 2018 | 05:22 PM
peterniez's Avatar
Dealer did not find anything, could not duplicate problem!!! They told me because they have an indoor parking lot, its warm in the building, they cannot duplicate the problem! :0
I made another appointment at a different dealer.... meanwhile...
I took your advise to check the temperature sensor(s)..
Outside Temperature 24F
After a Full Warmup (15min)
Using my scanner I found...
Engine Coolant Temperature 181F
Engine Coolant Temperature (2) 55F
I believe that sensor 2 should read close to sensor 1???
Am I safe to assume that sensor 2 is malfunctioning?
Should I just replace the sensor and cross my fingers?
Old Jan 9, 2018 | 08:08 AM
peterniez's Avatar
So I decided to replace sensor #2 since it was reading low temperature.
According to shopkey, sensor #2 is the one in front of the engine. (I took some screen shots)
This morning, I guess the car a bit better.. however I am not 100% convinced that this solved the problem as I did notice an RPM drop and a bit of hesitation/jerking. Outside temperatures have been better, not as cold as before.
I guess I will replace the other sensor too..... that one is a bit header to reach.
Can anyone give me any pointers to see if I'm going in the right direction...??
Old Jan 25, 2018 | 11:36 AM
peterniez's Avatar
Changed Both Sensors... still same issues.
Car will stall first one or two stops and hesitate/poor shifting until its fully warmed up.
I plugged my scanner in and now I'm getting this code
P061 A-64
?? any ideas ??
Old Dec 25, 2024 | 01:11 AM
MikeLR4's Avatar
3rd Gear
Just curious if you came across a resolution. My 2011 LR4 is exhibiting the same behavior yours did.
P061 A-64
?? any ideas ??
Old Dec 25, 2024 | 06:49 AM
peterniez's Avatar
It turned out to have been low on transmission fluid. The torque converter killed the engine when it was cold and fluid didn't expand enough. When it got warm it was just enough fluid for the tyranny to operate correctly. This is why in the summer it wasn't a problem. Never had an issue since.
If you have an older LR4, it's time to do the transmission service anyway. Get the proper ZF fluid and the upgraded 2 part pan with filter. Will make your life alot easier. Fill it according to instructions. You can get everything from atlantic british. They even have videos.
My Lr4 Still on the road
Hope this helps.
Old Dec 26, 2024 | 07:23 AM
guy's Avatar
guy
“HOW” could have the transmission fluid be low on a sealed component? Unless it wasn’t filled properly on the previous change…
Old Dec 26, 2024 | 05:36 PM
MikeLR4's Avatar
3rd Gear
Thanks, Peter! I had a very reputable shop do the fluid and pan change. The symptoms occurred thereafter, and they thought the fluid might have been low, but it wasn’t. They did confirm they used ZF 6 in it, so we’re all stumped right now.
