Talk me out of an LR4
Old Oct 13, 2023 | 10:02 AM
CKIST's Avatar
Default Talk me out of an LR4
Hi Everyone!
Brand new here, but I have forever wanted a Discovery/LR4 style Land Rover. I recently found a 2016 LR4 with less than 40k miles on it. Clean Car Fax and service history. Can you guys give me anything that I am missing about the car that I should be looking into? Big things to avoid? Should I run? I am not a big DIY type person. Any help or advice would be greatly appreciated.
Old Oct 13, 2023 | 10:15 AM
DakotaTravler's Avatar
The 5.0 engines are crap.
Old Oct 13, 2023 | 12:10 PM
CKIST's Avatar
Its the V6 3.0. Does that change anything?
Old Oct 13, 2023 | 12:33 PM
keninnc's Avatar
If you are not a DIY person then don't buy.
If you rely on the dealer or shop be prepared to spend 10K on it from now until 100,000 miles on brakes, coolant crossover pipes and control arms. If you are DIY these are all done at reasonable costs but having shops do them will add up to most likely half what your are going to buy the LR4 for.
Old Oct 13, 2023 | 01:18 PM
kajtzu's Avatar
Make sure you’ve got a fat wallet going in. You’re going to spend more money than your average Joe at a gentlemen’s club unless you work on it yourself.
Old Oct 14, 2023 | 05:59 AM
guy's Avatar
guy
Driving them for what they are designed to do is beyond reproach.
Or just cruising out to ski country, luxurious.
But
The cost of entry, prohibitive for most.
The cost of maintenance, alarming if you have a history of maintaining a Toyota or F150.
These are very heavy vehicles, by design. Tires, brakes, fuel, go quick.
And with the full time 4 wheel drive system ( as opposed to AWD found in the wannabees ). expensive to maintain.
If you decide you’re up for it, check the maintenance history. A poorly maintained vehicle means significant repairs will follow.
And immediately following the acquisition, change every fluid, filter, most hoses, batteries (there are 2) check bushings,…
Old Oct 16, 2023 | 10:19 AM
Troyan2019's Avatar
Originally Posted by CKIST
Hi Everyone!
Welcome. A 2016 with only 40K miles on it would be an incredible find. First, hit the advanced search on here and try looking for "first time buyer" or "buyer advice" in the LR4 forum. This search might work (or not): https://landroverforums.com/forum/se...archid=4724779
The LR4 is a great truck. I have a 2013 and it's the most fun vehicle I've ever had. You can see mine here: https://www.troyangrignon.com/vehicl...er-lr4-5-0-v8/ . I sold a 2018 4Runner to buy it and never looked back. You do need to find a solid independent LR mechanic and be really proactive about maintenance. I bought mine at 75K and immediately and preemptively swapped the coolant crossovers which are the achilles heel of these engines. If they fail, they do so catastrophically in less than 1 minute and you have a $15K-$25K engine to replace. I also did all fluids including transmission and transfer case (despite them being "life-time"), and upgraded wheels and tires. I also do the oil every 7500 miles (some do every 5000). The manufacturer recommendation of 15,000 is way off and was done for their own reasons.
So yeah they're reasonable to get into for what you get (because of the high depreciation) but they're expensive to maintain but incredible both on-road and off.
If you buy it, just do so with $5K set aside for immediate upkeep and another $5K set aside for ongoing maintenance and take care of it.
Old Oct 17, 2023 | 03:56 PM
rynoman1's Avatar
Hi Everyone!
I have a 2016 LR4. I bought it with 80K miles. It had a very well maintained service history like the one you're looking at. Does it have the HD package? That is a huge plus and was a requirement when I purchased mine. They can be expensive to maintain, but with that good of service history you should be good. I just finished a Moab and San Juan trip with mine. She was flawless
Old Feb 2, 2025 | 11:33 AM
irishrover25's Avatar
4wd High
What is the HD package?
Old Feb 2, 2025 | 05:19 PM
guy's Avatar
guy
Basically, the big ticket items of locking forward and rear diffs.
jalodge
LR4
42
Nov 4, 2024 02:34 AM
kst1980
LR4
Apr 28, 2023 08:53 PM
hawaiianbarbecue
LR4
Jan 8, 2023 04:09 AM
LeakyDisco
LR4
Feb 10, 2018 01:07 AM
iconoclast
LR4
Nov 16, 2017 07:20 AM
