TPMS Fault
Old Jul 2, 2021 | 09:16 AM
knightmetro's Avatar
Default TPMS Fault
Ok, the LAST thing I have to repair on this full rebuild is this TMPS fault I'm getting.
2012 LR4 HSE
I've got a TMPS Fault every time I start up the car. Pressures are were they are supposed to be. Once or twice it has gone away for a day.....but 99% of the time it's there.
Now there seems to be no real information on how to troubleshoot, reset, etc. I pulled the TPMS fuse, no dice. I unplugged and plugged both of the front fender sensors back in to make sure.
Any advice on how to troubleshoot? I took it to a tire shop and they said they couldn't help after I said "Land Rover".
Old Jul 2, 2021 | 04:38 PM
pagoda's Avatar
TPMS batteries only last 5-6 years. You may need to replace the in-wheel sensors - PITA as the tyre has to come off and the wheel rebalanced, etc. May be worth living with it until you need to change the tyres. If you do change them, try to use OEM (off Amazon, etc) rather than the cheapest you can find, as there are quality issues with the very cheap TPMS replacements it seems.
Taff61
Freelander
Jun 19, 2019 07:43 AM
Jlb
Oct 29, 2016 06:06 PM
e36m3
Feb 11, 2014 10:45 PM
chavhater
Nov 4, 2012 03:21 AM
