Transfer case/Diff/Transmission oil types for 2016 LR4
Old Mar 4, 2021 | 09:15 PM
Yu Sheng's Avatar
Originally Posted by Oldman846
That was a lot of posts. I hope I answer all of your questions.
yes. We have the 8HP70. Uses lifeguard 8 from the factory, but their are other alternatives. I personally use motul. Personally, I dropped and replaced my pan at 70K. It's up to you if you want to wait until 100K, but I would not go past that mileage.
you can use the Atlantic British kit. The fluids are the same. Differences occur with the drain/fill plugs for the transfer car and drain plug for the front diff. This is VIN specific. A quick call to Atlantic British will get you the right part.
Thank you for the reply. Mine is 56000 miles. I plan to change sooner than later.
Old Mar 5, 2021 | 06:17 AM
Oldman846's Avatar
Definitely appropriate to do a drain and fill of the transmission, but you can hold off on the full pan swap.
make sure you use the proper fill procedure.
Old Mar 8, 2021 | 09:24 AM
pagoda's Avatar
^^^what he says! It's not a straight forward process by any means.
I did this yesterday at 39K. I got about 3.8L out and a little more back in - around 4L allowing for spillage of the wretched stuff. Having cleared the adaptions on the transmission it shifts noticeably more smoothly.
One point about the diff oil listed above, it seems on AB's site to be for the 5.0L vehicle, rather than the later 3.0l.
Hughbullen
LR4
Oct 18, 2016 03:21 PM
LLLR4
Oct 9, 2016 11:40 AM
Josh darl
Defender
Sep 29, 2010 06:22 PM
safarisam
Jun 9, 2010 05:52 PM
jesse682000
Nov 11, 2007 10:54 AM
