Transmission fault, HDC fault, Parking brake fault, Engine system fault
Old Sep 11, 2019 | 09:05 AM
JeroPot's Avatar
Default Transmission fault, HDC fault, Parking brake fault, Engine system fault
Hi First time so may have been answered. car was fine until today .2014 discovery 4 (lr4) sdv6 se . started it up and multiple warning lights are now on my dash,.
doesnt go away and all functions suspened ie no ride hight selection no special function selection . tried the reset process without luck. any ideas appreciated
Old Sep 13, 2019 | 02:29 PM
abran's Avatar
battery, Alternator, brake switch, bad rear bulbs, corroded T case ECU( less common on an LR4), yada yada yada.
You will need a Gap tool to properly diagnose.
Old Feb 25, 2022 | 11:14 PM
warner429's Avatar
5th Gear
This issue ever get diagnosed. I have the same issue on my Lr4
Old Feb 26, 2022 | 09:26 AM
jahummer's Avatar
In my case it was the alternator outputting anywhere from 11 volts to 17 volts.
Old Feb 28, 2022 | 03:52 AM
Zwyde's Avatar
8th Gear
I also had the same issue a couple of weeks ago and it was the alternator.
Tonko007
May 6, 2018 03:01 AM
e36m3
Feb 11, 2014 10:45 PM
chavhater
Nov 4, 2012 03:21 AM
jcolumbia23
Oct 3, 2007 12:12 PM
