Used 2011 lr4
Old Feb 24, 2020 | 11:05 PM
Luis Fernando Gutierrez's Avatar
We went out to the San Gabriel Canyon OHV Area for our first LR4 Adventure this past weekend.
Feb. 22nd 2020
Old Feb 25, 2020 | 08:14 AM
WILLPULLEM's Avatar
Dirty intake is probably from the PCV return. There are two, one from each bank. Whats up the loose bolt on the lower right of your pic? Looks like a gm brand bolt as well. I could be wrong though
Old Feb 25, 2020 | 09:37 AM
Thanks, I'll look into a PCV Valve Service Kit. Yeah, that bolt doesn't look good... I'll provide an update soon.
Old Feb 25, 2020 | 01:08 PM
WILLPULLEM's Avatar
Wonder if you can run a catch can on that.. Therefore you wouldn't have as much oil going back through your intake and on the back of your valves. I am rebuilding a 5.0 right now and am planning on putting one on.
Old Feb 29, 2020 | 02:17 PM
I cleaned the Throttle Body today @ 88,090mi
02/29/2020
The bolt in question from the previous post seems to be threaded in with sealant! Where can I find the coolant system diagram?
Old Feb 29, 2020 | 08:52 PM
LED Bulbs to replace the Incandescent License Plate Bulbs. I’ve used the Sylvania ZEVO LED’s but for the License Plate regular LED’s seem sufficient...
02/29/2020
Sylvania LED @ 16.99
License Plate Frame & Protective Cover @ $19.99
Subtotal $36.98
CA Tax $3.51
AutoZone Rewards -$20.31
Old Mar 7, 2020 | 06:18 PM
Replaced the Incandescent Bulbs in Dome & Footwell Lights
Sylvania ZEVO LED $21.49
Subtotal $42.98
CA Tax $4.08
AutoZone Rewards -$20.00
Old Mar 15, 2020 | 08:50 PM
Upgraded the Low Beam Incandescent Bulbs to LED’s.
FAHREN Model: F6A @ $43.79
Old Mar 19, 2020 | 12:41 PM
AccuVision by SPLASH Front Window Wipers 22" @ $0.00
SafeView by SPLASH Rear Window Wiper 13" @ $0.00 (Incorrect Size but FREE!)
Lightning to 3.5mm Audio Cable by Apple for AUX connectivity @ $32.80
Old Mar 19, 2020 | 03:35 PM
how did you like the led low beam kit?
