Dirty intake is probably from the PCV return. There are two, one from each bank. Whats up the loose bolt on the lower right of your pic? Looks like a gm brand bolt as well. I could be wrong though
Thanks, I'll look into a PCV Valve Service Kit. Yeah, that bolt doesn't look good... I'll provide an update soon.
Wonder if you can run a catch can on that.. Therefore you wouldn't have as much oil going back through your intake and on the back of your valves. I am rebuilding a 5.0 right now and am planning on putting one on.
LED Bulbs to replace the Incandescent License Plate Bulbs. I’ve used the Sylvania ZEVO LED’s but for the License Plate regular LED’s seem sufficient...
AccuVision by SPLASH Front Window Wipers 22" @ $0.00
SafeView by SPLASH Rear Window Wiper 13" @ $0.00 (Incorrect Size but FREE!)
Lightning to 3.5mm Audio Cable by Apple for AUX connectivity @ $32.80
