Want to install roof rails, afraid of breaking sunroofs?
Old May 5, 2021 | 10:41 PM
Yohann Dias's Avatar
Default Panoramic Glass Sorted
Originally Posted by bksteve
I tried to pry off the plugs but then realized I could just unscrew them once I got a good on the plastic.
Thanks bksteve I had the railings reinstalled by a specialist and he could not find anything wrong that might have stressed the glass. I put it down to inadvertent pressure on the glass when prying the screws. I had the glass “welded” by specialist and decided not to replace it since the cracks are barely visible, and thankfully hidden by the roof lining from inside the vehicle. I have decided not to replace the roof glass since the process seems very invasive and risky. Chalking this one down to experience!
Old May 7, 2021 | 10:37 AM
mmbirtcher's Avatar
I’ll be adding a GOBI roof rack soon, and figured if I break the glass I’ll submit it to insurance! Is that wrong??
Old Mar 21, 2024 | 09:34 PM
MSorensen's Avatar
Default Rail spacers thickness??
Originally Posted by COSwede
I just bought some short rails from craigslist and put them on my 2011 LR4 a few weeks ago. Oddly enough, the rails seem to fit perfectly without the thicker spacer under the rail. So why use the spacer? Without the thicker metal spacer between the rail and the roof mount, there is a chance that the rail itself will crack the glass roof. The spacers are there for a reason!!!
I suggest this particular youtube video, if you haven't seen it already:
How to fit extended roof rack rail to Land Rover Discovery 3 & 4 ( LR3/LR4 ) - YouTube
This video discusses the extended OEM roof rails but it is applicable for the short rails. Specifically at around 7 min 10 seconds the gent explains how the bolt, washer, spacer etc, go together but he doesn't really explain why the spacer is necessary.
It's an easy job after seeing the video. I was concerned about cutting the channel but it worked out great.
No worries about breaking glass!
Any questions about install, just ask me!
Johan
would anyone know the actual rail spacer thickness please?
raymondfrank
Apr 27, 2019 07:34 AM
Womble
Jul 30, 2015 01:58 AM
Rogue3308
Aug 13, 2013 07:32 PM
countzen
LR4
Jan 28, 2013 03:00 PM
dvs_dale
Feb 16, 2010 06:50 AM
