What’s the Science of the 5.0 Timing Chain issues?
Hello all, I have recently been somewhat paranoid about the timing chains in my 5.0, they seem slightly loose but have a documented repair from a year ago. My question is not about that though.
In researching this issue I hear very little about what causes the failures at such different times. I understand the mechanics of the aluminum guides and metal pins, but I don’t understand the correlation with poor/15k mile oil changes. I’ve heard of some with poor oil changes lasting 32k miles and I know people on this forum are approaching 200k on their originals.
What about the oil causes the chains to fail so rapidly? Are there any other circumstances that cause failure or at least accelerate failure? Such as lower octane gas, lugging the engine, high rpm, cold temps etc?
I’m seeking an answer about what mechanically happens to cause the failures and how these problematic behaviors influence it. Not just cause I’m concerned about mine, but curios about the intricacies of this issue.
Thank you for your insights!
By sticky you mean that they aren’t lubricated enough to fully extend and fully hold tension? Thank you for the input!
I do find that even at 5000 mile oil change intervals with premium synthetic 5w20 oil, the oil that is extracted is very black/dirty on these engines. I expect it is a direct result of the direct injection and carbon buildup effects. these carbon particles suspended in the oil would act as abrasives especially apparently on the timing chain rollers, cam gears etc. that coupled with the early design timing shoe allows a lot of slop on the chains...
