What else to tackle when doing coolant crossover?
Old Dec 17, 2021 | 12:21 AM
Myclem's Avatar
3rd Gear
Default What else to tackle when doing coolant crossover?
I know this topic is beaten to hell here and I apologize to those who are sick of seeing it, but new 2016 LR4 owner 50k miles.
Taking car into independent shop this week to do coolant crossover. What else should I have them do while they are in there? I’ve read water pumps, thermostat? I am all ears.
Old Dec 17, 2021 | 07:54 AM
DesignerV's Avatar
7th Gear
I'm not as familiar with the V6, but on my 2013 V8, when I did the crossover I also did the intake seals, water pump, thermostat, hoses, and coolant with OEM parts. Basically anything that came out during the repair or that I could get at while I was in there...
Old Dec 19, 2021 | 10:55 PM
jlglr4's Avatar
Make sure they do front and rear crossovers. Water pump and t-stat makes sense. Also - check idler pulleys and replace if they are at all suspect - they’ll shred your belts when they go (I think there’s a TSB on one of the idler pulleys). Supercharger coupler is another thing that is super easy to change when you have the supercharger off. The spring couplers wear out and start rattling like marbles. If its not addressed, the spring wears a groove into the shaft (there’s a TSB on the couplers/snout). LR replaces the whole snout, but many of us have just replaced the spring coupler with a solid coupler from Eaton as a preventative measure.
Old Dec 20, 2021 | 10:57 PM
Myclem's Avatar
3rd Gear
thanks! That makes sense.
MichiganRover
LR4
Dec 11, 2020 10:52 AM
Chris Charlton
LR4
Aug 2, 2019 01:11 PM
Brosnan
Jul 12, 2019 07:20 PM
MichiganRover
LR4
Feb 24, 2019 06:33 AM
asikuy
Mar 5, 2009 06:57 PM
