What is this plastic part that goes into water pump?
Does anyone know the part number for the small black plastic elbow that pushes into the fitting on the front of the water pump? I know a few people have broken theirs but have never see any orderable part number for it. Any help would be appreciated.
LR049989
LR045238
Hopefully that helps.
No no idea why the design change but it’s a pain in the rear to get the new hose in without taking the crossover valve or the thermostat off. Trust me, I tried unsuccessfully. While you’re in there, I’d change out crossover valve, the oil cooler pipe, and water pump if they have not already been done. Doing everything is worthwhile and not a ton of additional effort involved.
Best of luck.
sschmerge, I see you haven't logged on in some time. Perhaps someone else could help me.
I too broke that plastic elbow while changing a water pump.
I ordered LR049989 and LR045238.
Since land rover changed the design, I'm confused on the hookups. The part LR045238 has a 'Y'. The ****** nipple on LR045238 is where the plastic elbow (and small hose) used to go, but now that's on LR049989. So, what goes on the barb of LR045238 now? Cap it?
Thanks for your help.
