where to buy AMK compressor?
Old Dec 27, 2019 | 11:03 AM
Laketahoe1981's Avatar
8th Gear
Default where to buy AMK compressor?
I made a foolish mistake by purchasing one of those Chinese AMK compressors to replace the Hitachi in my lr4. I had a shop update the software, and while everything "works" it is very noisy. You can feel the vibration into the driver seat and the compressor stays on longer than it should. I need to purchase an OEM AMK. Does anyone know where to find an OEM, not at dealership pricing?
Old Dec 27, 2019 | 06:17 PM
LR Techniker's Avatar
Be careful buying AMK compressors, as there are two styles out there. The "old" style, which was still failure prone and the "new" style which requires an update to the lines (cut and splice w/ install kit).
As for being very noisy, it is also possible they did not install it properly. It should be suspended on rubber/spring mounts to isolate the noise. It could be grounding out transmitting noises.
As for where to buy, check out the site's vendors.
Old Jan 5, 2020 | 11:15 AM
abran's Avatar
Also if they did not fit the cover properly or if they used your old Hitachi cover that could be the noise issue, but those Chinese AMKs suck. It will fail soon anyways, usually a fault with the main electrical connector at the compressor.
jafir
Aug 12, 2021 08:36 PM
memphis_rover
Feb 1, 2018 03:51 AM
Roverrrgirl
Jun 17, 2016 09:32 AM
Morgan1281
Apr 20, 2016 12:02 AM
Cottrell
Nov 8, 2012 02:17 PM
