Compressor control
Old Nov 6, 2012 | 03:22 PM
Cottrell's Avatar
Default Compressor control
Does anyone know if the EAS system just cuts power to the compressor once the psi is reached or does it use another method. I would really like to know because I am tired of the OEM compressor it's slow, expensive, and unreliable.
Old Nov 6, 2012 | 05:17 PM
04duxlr's Avatar
Here's some info on the cmpressor operation: Range Rover Air Compressor Replacement
There is a pressure switch on the valve block that turns the compressor on at 120 psi and off at 150 psi. You can switch to another compressor and many have done so but the stock unit is a rugged pump. The problem is that most out there now are old and tired. I doubt any replacement compressor will last 120,000+ miles. A new OEM compressor is not cheap and your pump may be too used up to rebuild but if you go with a cheaper aftermarket unit you will probably go through a few of them if you hang on to this vehicle.
Old Nov 7, 2012 | 06:38 PM
Cottrell's Avatar
Yes, I also read that the aftermarket pumps are not as hardy that is why I am going with a slightly more expensive, but much tougher pump 100% duty cycle 0-145psi in 2min 45sec.
Old Nov 7, 2012 | 08:30 PM
Rovin4life's Avatar
did you check for leaks?
Old Nov 8, 2012 | 08:41 AM
04duxlr's Avatar
The Rover EAS needs to get to 150 psi before the pressure valve shuts off the compressor. Also, is the quoted time to pressure for the internal tank on the compressor or have you figured this out for the system in the Rover? The EAS tank is pretty big.
Old Nov 8, 2012 | 02:17 PM
Cottrell's Avatar
Well I read in the RAVE that the tank is a 3 gallon I believe (dont hold me to that). Also I had to be sure so here is the stats on the new comp.
Performance Data
PSI CFM A BAR LPM A
0 1.76 10 0 50.0 10
10 1.66 12 1.0 46.0 13
20 1.59 14 2.0 43.0 14
30 1.52 15 3.0 40.5 17
40 1.45 16 4.0 38.5 18
50 1.41 17 5.0 35.5 19
60 1.34 18 6.0 33.0 19
70 1.27 18 7.0 31.5 19
80 1.20 19 8.0 29.5 20
90 1.16 19 9.0 27.0 20
100 1.13 19 10.0 25.0 19
110 1.06 20 11.0 23.0 19
120 1.02 20 12.0 20.5 19
130 0.95 20 13.0 18.0 18
140 0.92 19 14.0 15.5 18
150 0.85 19
160 0.81 19
170 0.74 19
180 0.70 19
190 0.63 18
200 0.56 18 *Supply Voltage: 13.8 Volts
Fill Rates
2.5 Gallon Tank Fill Rate
0 To 145 PSI 2 Min. 29 Sec.
110 To 145 PSI 57 Sec.
0 to 200 PSI 5 Min. 02 Sec.
165 to 200 PSI 1 Min. 23 Sec.
Rovin4life, yes i did check for leaks, and had them o'ring kit is on the way so is the compressor rebuild kit. I guess I will just rebuild and sell.
Green Blood
Dec 22, 2018 04:40 PM
Evan5291
Nov 21, 2017 07:59 AM
moorebl
Oct 3, 2014 09:59 AM
gamecockdisco
Jul 12, 2010 08:34 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
