02 d2 4.0 to 4.6 pcm/programming flash q's
So I recently completed building my motor and putting in it the car and it runs awesome. I just have not found anyone or any info of flashing the pcm/dme.
What was done:
Darton sleeves top hat liners
4.6 crank
4.6 rods
4.0 pistons for higher compression
kent cams performance cam
4.6 fuel injectors (though I found out they are the same as 4.0 lol)
4.6 mass air flow sensor with air boot
The truck is non air injected. I tried running the 4.6 maf but it was throwing bank one and two too lean codes. No CEL with the 4.0 maf so its back on currently till I figure out the flash stuff.
Anyone have advice or know who does this type of flash?
Located in ATL GA.
Thanks and any info would be appreciated.
What was done:
4.6 crank
4.6 rods
Located in ATL GA.
Do you have the contact for Will?
badassbmwm3 (03-29-2015)
Thanks
03discoman
01-14-2010 09:11 AM
