02 d2 4.0 to 4.6 pcm/programming flash q's
Old Mar 25, 2015 | 11:25 PM
badassbmwm3's Avatar
Default 02 d2 4.0 to 4.6 pcm/programming flash q's
So I recently completed building my motor and putting in it the car and it runs awesome. I just have not found anyone or any info of flashing the pcm/dme.
What was done:
Darton sleeves top hat liners
4.6 crank
4.6 rods
4.0 pistons for higher compression
kent cams performance cam
4.6 fuel injectors (though I found out they are the same as 4.0 lol)
4.6 mass air flow sensor with air boot
The truck is non air injected. I tried running the 4.6 maf but it was throwing bank one and two too lean codes. No CEL with the 4.0 maf so its back on currently till I figure out the flash stuff.
Anyone have advice or know who does this type of flash?
Located in ATL GA.
Thanks and any info would be appreciated.
Old Mar 26, 2015 | 10:08 AM
drowssap's Avatar
In your area will tillery i believe can help you. But ive also been told the 4.0 runs pretty rich to begin with so you may not have to.
Old Mar 27, 2015 | 09:53 AM
It does run and very well. It's better then before but I feel like there is more power hiding in my motor I would like to unleash.
Do you have the contact for Will?
Old Mar 27, 2015 | 10:27 AM
drowssap's Avatar
#1 Community For Land Rover Owners - The Rova Guy
Old Mar 29, 2015 | 06:26 PM
Their website doesn't appear to be working. I'll try to get in touch with them one way or another this monday. If anyone has a phone number or physical address, lmk.
Thanks
Brisket
Aug 10, 2011 07:49 PM
OKRover
Jul 21, 2010 08:16 PM
03discoman
Jan 14, 2010 09:11 AM
jfoley1
Mar 18, 2009 06:52 PM
riebs
Sep 20, 2006 03:40 PM
