4.0 to 4.6, Battle plan and things to look out for?
Joemamma1954 (03-20-2015)
I run 93 octane gas, 21 gal in tank, and 2 gallons of 110 to prevent knock. Engine runs good, has a lot of power from 3-5k with a bit of dead spot below 2 (probably caused by the cam).
I also have flowed heads, which may be less efficient at low rpm.
Did you ever build this? I just finished this exact build, but with stock 4.6 pistons, and a new oem 4.6 cam. Besides Bosch pink top fuel injectors and a decatted exhaust, everything else is stock. I gotta say I'm pretty pleased with the power. I've only put about 200 miles on it so far, but every time I drive it I feel a little more power from it loosening up. With the 4.0 I had 245/75/16 standard load tires, and it couldn't even hold slight inclines on the interstate. I also consistently got 9-10mpg (lots of hills here). Now it has 255/85/16s D-load tires and I can accelerate up inclines on the interstate while in overdrive. I'm also getting 11-12mpg. It still has all stock gearing, and even with 33s it is staying that way. The 4.6 compensates enough for me.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
She's not loose yet! about 50 miles on it since! So far, runs great with a TON of low lope. I have no exhausts on it, lmfao. Its just open headers, which made for a rather nasty sounding 50 miles and tons of fun.
I've opened it up a couple of times, and boy does she sing. I know I probably shouldn't, but man I can't resist. Tons of power honestly, doesn't feel slow AT ALL. I'm running 93/110 mix but yeah no pinging/knock to speak of. I may try 93 and see how that's like.
Ill be sure to upload some videos, as well as some accelerations and maybe a dyno!!
Thanks for sticking with me, I haven't posted here in a while lol
Should have thought that one thru, rods are probably shorter on the 4.6. I remember stroking a small block chevy and used the hp rods i had, and had to purchase pistons that had pins in different place to keep from hitting the heads.
senior moment.
senior moment.
I've done a similar build, converting my 2000 Disco II with a 4.0 to 4.6. I used a 4.6 crank and connecting rods, but 4.0 pistons. I also used an advanced timing cam, the 53230 from Crower. I also used their cam-saver lifters. I have magna flow cats and muffler, removed resonator, and a snorkel air intake. I haven't ported or polished the heads, and probably won't. I did have the heads knocked down by about .015, and the block was honed, decked, and cylinders pinned. I had the 4.6 crank trued and the connecting rods trued, as well. They rods were almost all ok. 3 needed to be brought back into round by about .0002. The rebuild was easy, and I never had issues with the pistons coming up too high, either.
It sounds amazing, though, and has some crazy power differences. I don't use any specific fuel formulation, and I've never hit any knocking issues. My rig has been up and running for about 900 miles since the rebuild. I changed the oil about a month ago and found very little particulate matter, and the magnetic drain bolt had some metallic sludge, but not enough to be worried about. I am considering doing a custom power-chip job by a few places that will remap the ECU, but even without, it has some amazing pick-up-and-go. I'll consider remapping more later. Right now, I am working on the steering and electrical mods.
Hope that helps for comparison, and I hope it all turned out well.
Chris Collins
04-21-2009 08:57 PM
