Air Compressor (suspension)
Old Apr 15, 2011 | 05:54 PM
publius's Avatar
Default Air Compressor (suspension)
Is there a way (relatively safely in regard to breaking something) to modify the suspension air compressor to take an air hose for airing up tires? Late '80's range Rover. The only tire I've changed in the last 20 years was a blowout on a trailer, I plug them on site. Much quicker and it has to be done anyway.
Old Apr 17, 2011 | 11:12 AM
I have no idea.
Old Apr 24, 2011 | 11:07 PM
DiscoIsNotDead's Avatar
I have no idea what kind of air lines are on it, but shouldn't be hard to hook up a "T" fitting in-line, and a 3/8'' air hose female end for an air hose. I'm sure i have the kind of stuff laying around whether its hard plastic lines, (use push-lok fittings) or stainless, or rubber, even easier to just use brass fittings available at any hardware store. I have a portable 5gal air tank i just use in my Bronco or i can just throw it in the back of the rover and air up @ the gas station before going anywhere. Just another thought.
5gal tank doesn't hold enough to air up all the tires to recommended psi, but definitely better than "bagged" tires on the street. Only brings one of my Bronco tires (35x 12.50) from about 5psi to 15. Eventually it will reach a balance between the two, and wont fill anymore.
Old Apr 25, 2011 | 08:21 AM
"NOPE"!!!
That was is not designed to make that sort of pressure or run long enough to fill all 4 after a run.
Old Apr 25, 2011 | 11:02 AM
publius's Avatar
I think you're misunderstanding me Mike. What I'm talking about is having a flat on the road, say it's a nail. I pull the nail and plug the hole. Now I want to air up the one tire and get back on the road.
Old Apr 25, 2011 | 12:43 PM
souljad9's Avatar
The pump isn't designed for that much, you'll probably blow it out the first time you do it. But using a tee, to a quick coupler theoretically would do it.
Old Apr 27, 2011 | 08:59 AM
drowssap's Avatar
I believe that Range Rover use a set of storage tanks to hold air, at least that is what it looks like on ebay. If you were to mount the storage tanks under your truck next to the frame rail, it maybe possible that the SLS compressor would work.That way you would be filling your tire from the tanks rather than the compressor trying to keep up.
It sounds good in theroy anyway, the compressor would not be under a load as you could preasurize the tanks a little at a time and you would have a larger volume of air on hand. It's just something I was thining about doing to mine as I plan on running and air operated CDL.
Old Apr 27, 2011 | 01:05 PM
It's not possible.
Paul Grant
Apr 2, 2012 07:44 AM
fastrx7man
Jan 28, 2012 12:49 PM
wsroufe
Feb 8, 2011 09:48 PM
anhernandez
Aug 18, 2009 12:47 AM
Gavster
Aug 14, 2009 10:28 PM
