bumper building
Old Apr 3, 2014 | 07:20 PM
TOM R's Avatar
Default bumper building
We are gonna be building a front bumper and try to keep it simple and light so gonna build box gussets for frame and weld a winch mount across top
Thinking tube bumper, what size tube is common?
Is welded tube OK or do I need dom tubing?
If I do one of those pre runner hoops what is the angle?
I also want to integrate a skid plate
Old Apr 4, 2014 | 09:26 AM
TOM R's Avatar
Beuler, beuler,,,,,beuler, beuler
Old Apr 4, 2014 | 11:15 AM
fishEH's Avatar
I'll try to remember to measure my tube for you when I get home.
Old Apr 4, 2014 | 12:12 PM
TOM R's Avatar
Instead of making boxes in 1/4 plate to fit over the frame horns is there a box tube the right size to fit?
Old Apr 4, 2014 | 05:17 PM
mattmo78's Avatar
I would think either 6 or 8 inch tube would be about the right height. Is that what you are looking for? I'm not sure what the angle for the pre-runner bar would be. I like the idea of a skid plate underneath, though.
Old Apr 5, 2014 | 02:09 PM
TOM R's Avatar
I figured the tube is 2" dia. Does the tube with weld seam and dom tube bent the same?
Old Apr 5, 2014 | 02:41 PM
Copper99's Avatar
6th Gear
I think a stinger hoop is set a 30* rake...........
I have been kicking around a simalar idea...
2" double tube spaced just enough to place a receiver hitch in the center.......then use receiver mounted winch that can be moved front to back if needed.
30* stinger in 1.5" with with tubes running down and back toward steering with a skid plate on them...........supported from the outer edge of bumper to frame horns by 1.5" tubes.
Welded black pipe should bend just fine........ I was thinkin schedule 10 pipe..
Idea based off of factory brush bar...........modified into proper bumper.........
Old Apr 5, 2014 | 05:45 PM
TOM R's Avatar
Looking to do a cross between a few others I have seen here are some samples I am pulling from
Old Apr 5, 2014 | 09:04 PM
CUpgt's Avatar
Run the main bar out of 2x.25 wall DOM, use 3/8" for the winch plate and 3/16" for the rest. Make sure you have two bolts through the frame horizontally and one vertically to keep it from rocking. I loved my tube bumper but it just didn't measure up to the Rovertym as far as brut strength, practical protection, and recovery points.
Old Apr 5, 2014 | 09:08 PM
CUpgt's Avatar
Virginia era early Rovertym
