CB Radios
I dont know if you checked my setup out saterday but I have a magnum radio with a monkey made antenna............I gotta say its not the cheapest of radio setups but itll definatly get out and talk to someone. If your looking for something just for wheeling I would get a Cobra 19 DX, there a nice compact unit, with a spring loaded base metal antenna, just my opinion but fiberglass antennas tend to break to easy
Brian i actually didnt get a good look at your truck on sat. i wanted too check out your rock sliders as well.. i was looking at a uniden unit and wanted to get firestix mounted to the rear bumper. i heard someone saying its useless to get dual if they are both mounted on the rear rather get one on the front and one on the rear. opinions?
Yeah I wouldnt bother with running 2 antennas it really doesnt help out that much more......I actually was running 2 on my 18 wheeler and it made my reception worse with 2 so I took the one off (now its on the disco). If you do put your antenna on the bumper make sure it has a good ground, some antennas do have a ground wire on them if your putting them on your bumperettes.
For inexpensive, compact radio the Uniden 510 or 520 are the way to go, IMO. I also like to have a radio with weather bands in an off road vehicle. The places I generally wheel it's really nice to be able to keep up to date on the weather conditions as they change. The Cobra 19 is a piece of junk. Midland 1001z is another compact radio that I would run before the Cobra 19. The Midland is available with weather scan also.
As for antenna, spend some money and get a Wilson 1000 or 5000 roof mount. The antenna is more important than the radio. You can run an inexpensive radio with a good antenna such as the Wilson with good results.
I ran a highly tweaked Uniden 78Elite with a 102" stainless whip on the rear bumper. It did a great job but definitely wasn't inexpensive and the antenna tended to whip around like crazy on rough trails.
1001z, base, cb, cobra, dealers, junk, midland, modification, modifications, mybb, ny, powered, radio, vbulletin, westchester
