front x springs..........
Old Feb 18, 2015 | 09:42 AM
dusty1's Avatar
Default front x springs..........
I have a set in the rear of my d2. like them. they work. currently have inverts up front. I am considering them up front, but a bit concerned with the possible interaction with shock. my rear ones allow for a lot more un centered expansion of the springs. I have a hard time imagining that the front shock will not get beat up and used as a guide rod.
anyone running them with this set up? seen anyone running them up front?does it work okay?
Old Feb 18, 2015 | 10:42 AM
fishEH's Avatar
Do you have a 3-link up front?
If not, I doubt your radius arms will allow for enough articulation to warrant X-springs. And looking at the design I don't see any way to use X-springs along with shocks mounted inside the coil. You'd have to mount the shocks externally, but still I don't see the point with stock radius arms.
Old Feb 18, 2015 | 11:17 AM
dusty1's Avatar
yeah that was my concern......moving the shocks. they have a hollow seat for the front, just haven't seen them in use.
I still have radius arms. I moved frame mounts back, built and stuck longer cranked arms in......so that helps a little bit. same on the rear, other direction. really I am trying to achieve a little more front axle downforce while on the long steep inclines....weightless front end is rough on the rear axles. rough
Old Feb 18, 2015 | 11:22 AM
dusty1's Avatar
yeah, I don't see how I can relocate.......no room...so friggin crowded....guess I will scrap the idea
Old Feb 26, 2015 | 08:18 PM
Buddy Lee's Avatar
How do you do inverted cones in the front and still have the shocks inside the spring?
Old Feb 26, 2015 | 08:30 PM
dusty1's Avatar
Duh...Dunno why I said inverted. Just tf501. Had inverts on back before swap. Plan to keep the shock in its intended location
rchrd0413
Apr 22, 2014 02:18 PM
bmw zhp
Apr 13, 2010 08:15 AM
jeremiah
Apr 2, 2010 02:16 PM
jcn
Sep 8, 2008 12:00 PM
R_Lefebvre
Jan 15, 2008 06:40 PM
