Grill Guard
Old Apr 1, 2006 | 03:27 PM
Cooper97Disco's Avatar
8th Gear
Default Grill Guard
Is it possible to put a Disco II grill guard on a 97 Disco I?
Old May 11, 2006 | 10:19 PM
hoberock's Avatar
Default RE: Grill Guard
Yes and no... I have a '97 with a Disco II front guard. The form of the guard is the same, but the mounting is different. The Disco I guard mounts are "L" shaped in go up to the frame. The Disco II mounts are basically straight. I built two bracket mounts and welded them to the bottom of the frame (just below the bumper mounts). If you are handy and can weld, then it isn't too bad. If you aren't, then find a friend or buy a Disco I guard. If you live in WA, you can stop by and I'll weld a set of mounts on your ride for you .
Tim
Alex_M
Feb 11, 2015 09:06 AM
DeluxeRN
Jul 31, 2011 10:06 PM
CANAMDiscovery
May 17, 2009 08:03 AM
tango123
May 2, 2009 01:48 PM
thunderchicken
May 10, 2005 01:23 AM
