I'm sorry, I can't hear you over my V12 Discovery...
If you plan on using the 4hp22, it won't hold.
I'm putting a BMW M70 into my RRC (been done once by a guy named Kito in the PNW), and using a 4hp24 that came with the M70. The trans housings are the same, so the t-case will/should bolt up....
I'm halfway into resealing the engine.
RRC currently has BMW M52B28, bolted right up to the stock trans.
Meh, M70s aren't that large. All alum. A running, dressed M70 is around 522lbs (HP rated at 295 and power/weight at 1.77lb/hp) Rover V8 is what, 507 fully dressed (Dimensions of the Rover V8 engine fully dressed, and weighing in at 230KG all up.)?
Please correct me if I'm wrong. I don't have a RV8 to weigh....but I do have a couple M70s.....
yeah me, to in process of cleaning and tarting up a m70 to put into the disco, using the guts of a zf4hp24 auto put into the 22 housing giving a hydraulic controlled auto with the 24 internals, and tranny bolts to the rear, Mega squirt the motor
Pedro
dusty1 (05-31-2015)
finally getting the motor back together
![](https://lh3.googleusercontent.com/Wx5i4jUjT5qeLsamLn1PybZOCvyowdu0JzTx1X5yKBc=s197-p-no)
need to get more bolts for the water return trough, old one a tad rusty, then can get inlets back on and in place, flip it over and refit the oil pick up and windage trays and finally sump, then a wire up and get it running on the floor and then begin to fit into engine bay, at this rate though it will be next year.
Pedro
Pedro
Landifan
01-18-2011 08:59 AM
AJPTransport
01-26-2010 10:40 AM
