Land Rover Safari 5000 Lamps Not fit in ARB Bumper? Here's Your Solution
Old Jul 23, 2012 | 09:01 PM
honda50r's Avatar
Default Land Rover Safari 5000 Lamps Not fit in ARB Bumper? Here's Your Solution
For all of you that have thought of trying to fit your 9 inch Genuine Land Rover Safari 5000 Driving Lamps in your 8 inch 1999-2002 ARB Bumper and saw they don't fit! Here's my solution! And yes, the bumper is on a D1 but it is an early D2 bumper. No guarantees on other models.
Anyways, here we go.
After lots of thought on alternative mounting positions and none of them sufficing how I like, I decided to make the lights work where they were designed to, in front of the grill directly behind the factory on the ARB Light Mounts. Simply enough, my LE trim Disco had factory fog lamps, so once the factory bumper was gone it left those plugs. I had been searching for quite awhile for these lamps and finally found some in great condition, plus, all I had to do was plug them into the old fog lamp plug!
Most importantly, I went to Lowe's and acquired a 3' x 1.5" x 1/8" piece of metal stock, unfinished. It was around ten bucks I think. Then, I proceeded to cut two 6"ish strips out of that metal. After that...
I spent about an hour at Lowe's today of buying bolts, returning them, trying another size, then finally finding what I needed. I'm glad I parked up front so I could walk back and forth between the truck and Lowe's, lol.
Old Jul 23, 2012 | 09:14 PM
honda50r's Avatar
...After that, I drilled two 3/8" holes on each side of the strips. Then sprayed them black.
(Sorry the pic is huge)
As you can tell, one hole was for the first bolt while the back hole was for the lamps themselves.
As the photo shows, it was around 2 inches of drop to get the lamp where I wanted it. For the front bolt, part#: Hillman#881773 This is a 3/8"-16 x 2 Hex Screw.
Shown here: Name:  IMG_20120723_193329.jpg
To keep the ridgidity, I used a 3/8" x 1.5" Stainless Steel Spacer, as you can also see in the photo below. This spacer had to be trimmed down about 1/8" to accommodate the nylon lock nut. In order to keep the top from "circling" around the ARB 1/2" light mount I had to use a washer underneath also. If I had to do it again, I would use a washer under the cap along with on top of the spacer, if that makes sense.
For the lamps, I replaced the factory stem with a 3/8" x 1" hex bolt of which accommodated the rear-most hole in the steel. It was also sinched up with a nylon lock nut. (Below under the lamp)
Finished product!
I was thinking of painting the hardware, but it would wear off soon anyways and look even worse. Plus, I don't mind the stainless steel accents at all.
I hope this helps somebody! That is my goal!
File Type: jpg
Old Jul 24, 2012 | 09:44 AM
fishEH's Avatar
Dumb question. Wouldn't they fit hung upside down from the upper tabs?
Old Jul 24, 2012 | 02:01 PM
honda50r's Avatar
Unfortunately no. The wires are too short and the base wont fit in the tabs from the bottom, its "boxed"
Old Jul 24, 2012 | 05:15 PM
fishEH's Avatar
Bummer. What beam are those? Wattage?
Old Jul 24, 2012 | 08:14 PM
yloDiscoII's Avatar
And the "Land Rover" oval would be upside down too
Looks good Honda, nice work, and nice write up.
dvnoriega
Mar 16, 2017 08:28 AM
rambo
Oct 17, 2013 10:13 PM
yloDiscoII
Nov 2, 2011 11:23 PM
jayzoid
Oct 18, 2011 11:31 PM
rovermike
Apr 2, 2007 12:18 AM
