led offroad lights
My 42" bar showed today I tried it battery direct an wow that's insane bright
If I go by my ultragauge it only draws like .10 volts and that's awesome since these have such weak alternators
What's the best way to mount this to my safety devices rack? Came with flat feet
are the mounts on the light bar the ones all the way at the end or underneath? if they are at the end, unscrew the feet, weld two tabs on the rack instead using the feet and bolt it up. if underneath, weld regular ole light tabs on the rack.
Why not use the feet? How am I supposed to lock the adjustment?
Also got 4 4" ones with single bolt mount, figured one each side 2 in back
Someones got to have a slick way to mount to the tubing without me grinding off bed liner and welding
