Lift Kit
Old Jan 5, 2009 | 06:58 PM
Classic89's Avatar
Default Lift Kit
I have an 89 Classic and I am looking to put some bigger tires possibly 285/75/16, what is going to be my best and least expensive option for getting enough lift to put bigger tires under it? Thanks
Old Jan 6, 2009 | 08:45 AM
Default RE: Lift Kit
Either a 2" OME lift kit or a 3" RTE kit, you have no other options as using a body lift on old springs will make for the worst possible ride off road.
Old Jan 6, 2009 | 08:40 PM
Classic89's Avatar
sorry but what brand is RTE and do you possibly what size tires I could put under it if I put like 2 inch spacers under the springs from Rovertyme? Thanks
Old Jan 7, 2009 | 01:17 AM
hazletbassist89's Avatar
RTE is rovertym.com If you put their 2 inch spacers you'll be able to fit a 265/75-16 or a 235/85-16. But I wouldn't recommend putting spacers. For a 2 inch lift just get yourself an OME or RTE setup. For a little more money than the spacers you get significantly better performance. And putting spacers under the worn out factory springs is unsafe, it raises your center of gravity and increases rollover chance.
Old Jan 7, 2009 | 09:35 AM
ORIGINAL: Classic89
Sounds like you are not familiar with Rovers and lifts. Consider sending me your tel number, I will be glad to walk you thru a possible lift.
caymandrew
May 9, 2015 10:05 PM
Bostonc16
Mar 7, 2015 10:32 AM
caspian
Feb 19, 2011 06:41 PM
majrmike
Oct 9, 2007 03:13 PM
studlee
Aug 8, 2006 10:29 PM
