lift question d1
Old Jun 10, 2010 | 02:07 PM
MountainOx's Avatar
Default lift question d1
i picked up a 98 D1 . planning on lifting it like my RRC.
i plan on lifting my truck 3 inches. will i need to do any drive line work. or will it be just like my classic. springs brake lines an shocks.
i saw the 5 inch lift springs. an they are recommending drive lines. along with the brake lines an shocks. i am fairly interested in going 5 inches. depending on the cost of drive line work. an who seems to have the most reliable drive lines?
i would like to know how your 3 and 5 inch lifts act for you on the d1's.
also is the d1 24 or 10 spline? i also noticed unlike my rrc this truck has the low an high lock .
Old Jun 10, 2010 | 02:51 PM
A 98 is a 24 spline.
As for a 3" lift, you are getting into the grey area when it comes to frive lines, so be prepared.
Old Jun 10, 2010 | 03:32 PM
MountainOx's Avatar
are there any major undercarriage differences between my 92 rover classic an the discovery?
Old Jun 10, 2010 | 04:31 PM
Classic was a little longer, may be depending on which one you had, the short, classic or LWB.
Old Jun 10, 2010 | 04:40 PM
MountainOx's Avatar
i had the shorter wheel base. so as i understand it. the axles an trans , engines are all the same.
the one i picked is a 40th or 50th anniversary. is there any thing i should know about it. i figure its pretty much the same as the rest of the d1s.
do the 98's have the aluminum block? an is there any thing i can do to ensure that i wont be having any sleeve problems? other than not over heating the engine.
Old Jun 11, 2010 | 11:59 AM
Long Haul's Avatar
yes your 98 D1 has an aluminum block..As far as lift goes 3" your about at your limit with your front driveshaft angle. I had to get a new front driveshaft made for mine with a double cardan at the t/case. Also 3" will really affect the caster angles on the front end and to fix that is new radius arms and new swivel *****, at least thats what it took to fix mine...
Good Luck
vibrolucky
Sep 25, 2013 10:28 AM
Emperor_MA
Jun 15, 2011 11:21 AM
calebbo
Feb 10, 2011 04:58 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
Bigmonty
Aug 8, 2007 07:13 AM
