looking for some lift
Old Sep 9, 2014 | 10:51 PM
LRlax11's Avatar
Default looking for some lift
I've got a completely stock 2004 disco 2 and I'm looking for a bit of a lift and some new tires any suggestions?
Old Sep 12, 2014 | 12:38 AM
mattmo78's Avatar
If you're serious into off-roading, an OME lift is what you need. It's a little more pricey, though... Ballpark of $700-$800. If you just want to do some occasional off-road stuff, and drive mostly pavement, go with a TerraFirma lift. Either way, a 2" lift is safest without having to switch out any other major components. If you go above that, you'll have to start changing out more expensive parts.
I believe you can go with 32" tires with a 2" lift, but you may have to trim some of your front bumper. Nitto tires have a pretty good selection. Lot of people run Goodyear tires too.
Old Sep 12, 2014 | 01:13 AM
Sir Axlerod's Avatar
32's no lift, no rub, full flex (no sway bar neither).
Went everywhere he did. just as easily...
Old Sep 12, 2014 | 11:39 AM
LRlax11's Avatar
would you suggest removing the stray bar?
Old Sep 12, 2014 | 03:12 PM
Yes.
Emphatically so.
Highway handling suffers slightly. I'm still running my rear as it does see the Tarmac regularly.
Old Sep 14, 2014 | 08:09 AM
LRlax11's Avatar
Yes.
Emphatically so.
would you suggest getting quick dismounts or just taking them off once and leaving them off
Old Sep 14, 2014 | 12:27 PM
I run 80 down I-90 (twisty Google Map Sat view 83837), and I'm fine. I also see more dirt than I do pavement, so in my case, off permanently is fine. If you see trails/rocks etc twice a year, quick disconnect and be happy. If you are more off road than on, the handling (albeit not Porsche like anymore, but i have my Dart for "slalom" activities) isn't compromised enough to hate the rig with it gone.
At 20 psi tire pressure with an overkill winch and brush bar, it WILL nose dive in a non complimentary manner, but at 40, I'm happy enough with it.
Also shot Highway 12 (Google Maps Sat View Kooskia,ID to Missoula, MT) at above posted mph's, with no sway bar.
Old Sep 14, 2014 | 02:47 PM
LRlax11's Avatar
I definitely see more pavement than dirt but my friend suggested quick disconnects for me to keep them on unless we are off-road
Old Sep 21, 2019 | 07:04 PM
mln01's Avatar
Landroverdude, where are you located?
Old Sep 23, 2019 | 07:23 AM
shanechevelle's Avatar
I wish location was sort of mandatory. I was talking to someone in NJ and they said they come here once in awhile. If I would have known NJ, I would have driven to help him. I'm going for about a 2 hour drive in any direction.
Landy Idaho
Jul 31, 2020 07:37 AM
DiscoPhipps78
Dec 5, 2012 10:52 AM
Erwan88
Feb 20, 2012 05:15 PM
Spike555
Aug 28, 2010 05:15 PM
sharp21
Dec 14, 2006 02:34 PM
