need a new manifold and distributor
Old Oct 8, 2012 | 11:04 PM
madcrawler girl's Avatar
Default need a new manifold and distributor
I have a 96 disco with the gems motor. Its all but buggies out now completely tubed. I just about had it done and was planning on taking it out that day when I had a small fire and the dash doors and all the wires under the dash melted.
I would like to run propane because it would clean up the wiring mess and eliminate the mess and frustration of trying to figure out what I need to make it run.
I have heard that there is an intake manifold and distributor from another vehicle that just literally bolts right on. You can find it in the junk yard. I just can't seem to find what one bolts up.
Do any of you have an idea or thoughts on what one to get or where.
Has any one done this swap?
Old Oct 9, 2012 | 09:04 AM
I doubt a 96 is worth the expense needed to do a conversion and repair your melt down.
Old Oct 9, 2012 | 09:24 AM
Actually Mike, with the amount of Fab work that has gone into it, if I was her I would rebuild it as well.
I replied on your thread on LRO with the info you needed.
Old Oct 9, 2012 | 11:53 AM
One thought would be looking at old conversions of the Rover V-8 from carb to fuel injection. Ought to be able to go backwards, and re-jet the carb for LP. Lots of standby generators had carb modded for LP. Can you do it? Probably. Is money better spent on another project? Or take the RAVE electrical diagrams and make your own harness? Your call.
Old Oct 9, 2012 | 12:18 PM
antichrist's Avatar
Do you have the other bits you need, like front cover, to install a distributor in a '96?
I believe it's an Edelbrock intake you want. Or one from a carbed Rover V8.
Old Oct 9, 2012 | 11:32 PM
zukijames's Avatar
thanks for standing up for her and helping her out..! hopefully we can get this thing on the trail soon!
sealsupra6
Feb 7, 2009 12:07 AM
dms98e
May 29, 2008 11:50 AM
motormikeyman
Apr 22, 2008 06:54 PM
mestupstud
Nov 10, 2007 07:49 AM
Ex CCS Racer
Tires
Oct 21, 2007 08:36 PM
