Prepping for lift - HD DC Front Drive Shaft
Old Sep 10, 2012 | 12:46 AM
  #21
BD_LR4's Avatar
And a few more.
You'll notice on the last 2 pics, the front driveshaft is very close to the sway bar, but not touching in this photo. If you look closely, you'll notice the zerk has rubbed the sway bar slightly (all this from less than 150 feet of driving). The driveshaft does appear to make contact at the same time the zerk does as can be seen by the worn sticker.
Attached Thumbnails Prepping for lift - HD DC Front Drive Shaft-img_1421.jpg   Prepping for lift - HD DC Front Drive Shaft-img_1422.jpg   Prepping for lift - HD DC Front Drive Shaft-img_1423.jpg   Prepping for lift - HD DC Front Drive Shaft-img_1424.jpg   Prepping for lift - HD DC Front Drive Shaft-img_1429.jpg
Old Sep 20, 2012 | 11:25 AM
  #22
tracked's Avatar
Default try this upgrade
i had upgraded my disco then the sport when we changed out we used phantom in manchester they came to us best thing since sliced bread wish we had done it a lot sooner
www.phantom.uk.net
Old Sep 23, 2012 | 11:51 PM
  #23
BD_LR4's Avatar
I finally received my sway bar lowering kit and installed that today. No more clunk from the driveshaft zerk hitting the sway bar!!!
Old Jan 2, 2013 | 12:23 AM
  #24
BD_LR4's Avatar
New tires (255/85R16 BFG MT KM2) - only needed a camel cut on the back. You'll notice the small nick i made when trimming the rear fender.
Attached Thumbnails Prepping for lift - HD DC Front Drive Shaft-p1020874.jpg   Prepping for lift - HD DC Front Drive Shaft-p1020882.jpg   Prepping for lift - HD DC Front Drive Shaft-p1020883.jpg   Prepping for lift - HD DC Front Drive Shaft-p1020889.jpg   Prepping for lift - HD DC Front Drive Shaft-p1020888.jpg
Old Jan 2, 2013 | 12:26 AM
  #25
BD_LR4's Avatar
Not quite the same articulations as FishEh But still pretty good for an OME shock with sway bars still connected. More pics to follow, including the steering damper relocation and HD drag link. Sorry, no photos of the HD High Clearance Tie Rod.
Attached Thumbnails Prepping for lift - HD DC Front Drive Shaft-p1020890.jpg   Prepping for lift - HD DC Front Drive Shaft-p1020892.jpg   Prepping for lift - HD DC Front Drive Shaft-p1020893.jpg   Prepping for lift - HD DC Front Drive Shaft-p1020894.jpg   Prepping for lift - HD DC Front Drive Shaft-p1020896.jpg
Old Jan 2, 2013 | 12:29 AM
  #26
BD_LR4's Avatar
Finally got the rig off road and into some mud. I didn't realize the whole was so big - the mud almost swallowed the car. The entire hood was submerged for about 15 seconds! Yikes!!! Fortunately, everything still runs fine.
Attached Thumbnails Prepping for lift - HD DC Front Drive Shaft-p1020897.jpg   Prepping for lift - HD DC Front Drive Shaft-p1020900.jpg   Prepping for lift - HD DC Front Drive Shaft-p1020902.jpg
Old Jan 2, 2013 | 03:33 PM
  #27
sochuck's Avatar
great looking ride!
Old Apr 7, 2013 | 06:27 PM
  #28
1danger1's Avatar
I used PB blaster on mine the night before and all 8 nuts came off in 20 mins with a set of box wrenches.
DiscoJon
Jul 14, 2019 01:51 PM
Doogwhan
Dec 26, 2014 11:56 PM
lambo
Nov 19, 2013 10:54 AM
30more
Jul 9, 2012 03:15 PM
TripleThreat
Apr 12, 2011 08:58 AM
