Secondary Air Injection
I'm installing a 4.6L Thor engine from an '01 Range Rover into a British sports car. I've discovered the engine has Secondary Air Injection. I have learned that the SAI system is needed to keep the ECU happy, but I am tossing out the stock ECU/BCM and converting to Megasquirt. I live in rural TX where there are no emissions tests, and I plan to register the car as a '68, since that's what the car VIN identifies.
So, can I remove the SAI stuff - the valves on each cylinder bank, their hoses and the pump? If so, do I need to do anything more that plug the SAI injector sockets in the heads?.
And why are there two radiators available - one for the non-SAI 4.6L and one or the SAI-equipped 4,6L? Do SAI equipped engines run hotter and therefore the heads need more cooling?
Thanks,
Bill
Thanks,
Bill
Thanks,
Bill
Thanks,
Bill
